I need a program to create "portrait" wallpapers...
mitchellvii
Hi all,
I use a Live Wallpaper .apk called "Waterize Live" that is very cool. You can basically make any wallpaper look like it is submerged in water.
Anyway, the only problem is that it only takes images that are sized perfectly to fit in "portrait" mode on your EVO. I will use larger images, but squish them to fit.
I am looking for a wallpaper editing program that will take my normal EVO wallpapers are create these "portrait" sized versions for me. If no such app exists, can someone tell me the exact dimensions on EVO portrait view?
Thanks.
