Root i need a stock 2.2 kernal
This is a pretty old thread. If that is the stock 2.2 kernel, it's from the first 2.2 OTA. You definitely don't want that. Which 2.2 kernel do you want (read as: which sw version 3.29, 3.30, or 3.70?). I forget which ones are which exactly, but I know 3.30 had HTC #17 and the latest 3.70 has HTC #15. I'm sure you can find them over at xda. I can search for them if you know which one you want.
what would the difference be between the 3 you listed? I downloaded this one found in the rooting for dummies thread StockKernel.32.zip
