Root I need... blur_yahoo.apk
I deleted it before i found out that it makes the contacts force close. can someone please post that apk so i can get my contacts to work again? Thanks.
Highly appreciated!
However, when i try to install it, it says "install unsuccessful.
I emailed it to myself, and tried to install it from gmail. Also downloaded it to sdcard and tried installing it using astro, and no go on that either. Know what im doing wrong?
Highly appreciated!
Use Root Explorer to move it to /system/app/.
Ok, Tried that. I was able to put the .apk in the /system/app folder, but it still doesnt install. When i click install after moving it to that folder it comes back with the same "did not install" message. I also noticed there is a .odex file under each .apk file, But not under the blur_yahoo.apk file. What am i doing wrong here!!!
Unfortunately, I can't give you the files in question, but I can tell you what to do and what you're doing wrong.
You don't want to "Install" it at all. What you want to do is move the blur_yahoo.apk and blur_yahoo.odex files to /system/app, then long press on them and change their permissions to:
Owner/User: Read/Write
Group: Read
Other: Read
Then reboot. Don't launch the APK or install it. Just reboot, and it'll come up happy.
You could try the files from the Odexed Gingerbread release of the Droid X that I posted here:
http://androidforums.com/droid-x-al...files-safe-remove-gingerbread-gingerblur.html
No promises, though. Someone needs to post both the APK and the ODEX file for you.
in the future OP freeze the bloat instead of deleting it.
this is a tad late, but you can also rename files to .bak in root explorer or move them using batch to another location on an SD card. If you do that though, you will need to change their permissions to:
Group: Read
Other: Read
I personally recommend renaming them instead of freezing...but it does the same thing.
Group: Read
Other: Read
I performed the above, but still am unable to edit contacts anymore. Is there something I'm missing?
Thanks in advance.
