scotty85
Extreme Android User
I kind of gave up. I didn't remove the sd card, but I guess that's worth a shot... I was in hboot earlier, but couldn't get into fastboot![]()
sorry youre not having luck
if you cant get to fastboot, maybe just try turning the phone on once a day and leave it for a couple hours... maybe sometime it will boot.
if you can get to a point where you can select in hboot,you might also try a factory reset
