Root i need help badly i think i might had bricked
discua8
i need help badly i think i might had bricked my phone i i tryed doin a factory reset from the settins nd it took me to the cwm. so i basically wipe data , cache nd dalvik. thn i flash ldk ick but when i restart my phone it keeps on takin me to the cwm menu. idk wat to do now nd i really need my phone.. plz help me.
lolz.. yea. well. i install the exit recovery. on it.. nd it did work m8. im glad .. but thank very much for your assistence..
Did you get it :confused:
how do i install exitrecovery? wheres it located..i keep booting into clockwork....
Exitrecovery would be if your phone got stuck in the rebooting cycle. You are not...when you wiped data/factory you deleted a ROM for the phone to boot into.
Sooo...shut off your phone. Pull out your external sd card...use the adapter and insert it into your computer-download this ROM onto your sd card
http://dl.dropbox.com/u/27980360/LDK-ICK v1.4.zip
Do not exstract it(unzip it) on your computer choose save.
Pull your sd out of CPU..insert sd into phone...boot up phone...install zip from sd...runs...reboot...shoud load up to that ROM
i did this and it just rebooted back into clockwork recovery
Were you able to see the ROM you put on the sd to choose it ...
K...I'm back up and running..used the exitrecovery.zip...and the ROM u linked me was flashed...how do I get my phone back to factory everything ...I'm selling to a worker at metro and I know he will try to reset as I did....thank you all for input ...I'm trying out the connect if I can get this sold
Just click
on all the post and we call it even;)
alright so i was trying to update my cyanogen mod nightly and all of a sudden it went to boot loop again and again. i read/searched forums and found out that exitrecovery.zip is needed to be flashed. i got the file on my sdcard and flashed it and NOW my phone will NOT turn on at all. it cant be battery because i used my wifes phone battery(she has same phone) and it still doesnt turn on. what could possibly be the reason for this brick?? is it bricked??
What kind of phone do you have?
I'm sure the esteem community can help you out, we're friggen awesome!...
But we do not have cyanogen mod on our device.......YET :D
(thank u PG)
