Root I need help! I have an INCREDIBLE issue!!
And after you try those, check out Virtuous. It is very close to
VZN stock. It removes some crapware by default, and with its
configuration utility, 'Virtuous Buddy', you can delete all the other
things you don't want starting - SAVE THE BATTERY. If you're
handy with reading instructions, download and flash Hey It's Lou's
#8. That combination for me has resulted in a very quick Incredible
whose battery life is 100% improved from grunt stock.
Nothing happens when I flash different ROM's over and over as long as I make nandriod backups and do a full wipe right? And how will I know which version of Clockwork to use? Because I've read around and some ROM's use older versions of Clockwork and I don't know where to find those. And what's the whole deal with flashing a ROM on top of a ROM?
