Technically you aren't even supposed to use windows anymore. Team unlimited only supports Linux. You can make a live ubuntu dvd if you don't have Linux natively installed.
If you use the guide stickied at the top of this section, I believe it has the old windows version. It works on 64 bit.
Just be warned that unlimited will not offer any support if you do not follow their instructions to the letter.
i just s-offed like 5 minutes ago on a 64 bit computer lol, totally works for me every time, and to make it easier, just use a paperclip and some electrical tape. easiest way i believe, goodluck!
64 bit windows 7? and yeah i tried it with a regular wire and nothing happened just deleted my custom recovery but i re flashed again through my computer. so if try again with a paperclip and electrical tape might work right?
