Root I need help rooting my Facinate.
10sc
Below is the meat of what I get using Dirrk's EZ Root v0.2.
The root files seem to be working until the very end. Everything appears fine until the mount operation.
I've tried with the SD card mounted, not mounted, and even with the SD card out of the phone. ARGHHHHHHHHHH!!!!!!!
What am I missing?
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
I500a7e50bae device
* Pushing the files to your phone
* rage.bin, busybox, Superuser.apk, su, com.sh
218 KB/s (0 bytes in 1867568.008s)
182 KB/s (0 bytes in 26264.000s)
170 KB/s (0 bytes in 196521.001s)
42 KB/s (0 bytes in 5392.000s)
8 KB/s (0 bytes in 281.000s)
** Successfully exploited, installing permanent root files and deleting temp files
mount: Operation not permitted
/data/local/tmp/com.sh: cannot create /system/xbin/su: read-only file system
/data/local/tmp/com.sh: cannot create /system/xbin/busybox: read-only file syste
m
/data/local/tmp/com.sh: cannot create /system/app/Superuser.apk: read-only file
system
Unable to chmod /system/xbin/su: No such file or directory
Unable to chmod /system/xbin/busybox: No such file or directory
I've been using SuperOneClick found here. It's worked for me many times. Just make sure you have the drivers for the phone installed and make sure that USB Debugging is enabled.
