Help I need help syncing
I just joined this forum and thinks its awesome.
Having an issue syncing. My database is ACT 2009 and I sync through a third party software called companionlink of which I run version 3. I have been using this for years with Blackberry and never had an issue.
The issue is not with the syncing, its once I have the data (contacts) in my HTC EVO. I can open a contact and view it but cant make any changes (edit) to it at all. On the top right hand corner of the screen its says facebook. When I select Menu from within the contact my only options are All, Link and Set Speed Dial.
I am sure that when I do my initial sync overwriting my EVO it is putting the contacts into the wrong type of contacts
