frusciante54
Member
Hello. This is a very complicated issue but I'm going to try my best to explain this.
(General Mobile GM5 Plus - Android Nougat 7.0 - Stock Android/Android One)
I'm a bit of a control maniac when it comes to memories. I need everything to stay exactly the same. That includes the file itself and the created time. So that the gallery will work fine. When I scroll to the end of the gallery, I need to be able to know the first photo that I've taken. That's called timestamps I guess. When you take a photo or a screenshot, it sends some info inside the file.
And my new device, which I've been experiencing lots of software problems with, is changing that timestamp. Let me give you an example.
There is a photo that I've taken in 2014. When I copy it to my older phone, it doesn't change anything. It just copies the exact same, original file with the original timestamps.
But when I copy that file to my new device, it changes the created time for some reason. It changes the created time to the date when I copy that file (in this case, 2016).
So the photo that I've taken in 2014 says that I've taken this picture just now. Weird. Right?
Your reaction may be "Is this a real problem, really? Is it really that important?" but it is to me. If I've taken that photo on 2014, it has to contain that information.
Fortunetly I have a backup which contains those original files with the original timestamps on them. So if you know a way to stop this timestamp changing... I would really appriciate it.
Thank you!
Thank you!
But I can manually synch the screenshots, I know that. But they don't have a "photo taken date" so when I download them to my computer, then don't have the right timestamps on them.
