CafeKampuchia Android Expert May 10, 2012 #2 Link2SD is the better route. Check out this guide: [TUTORIAL][Link2SD][ROOT]Updated! How to prep your SD card for it...Windoze Style Don't worry about the Linux swap partition found in the second post.
Hendoe Well-Known Member May 10, 2012 #3 thank you CafeKampuchia said: Link2SD is the better route. Check out this guide: [TUTORIAL][Link2SD][ROOT]Updated! How to prep your SD card for it...Windoze Style Don't worry about the Linux swap partition found in the second post. Click to expand...
Hendoe Well-Known Member May 10, 2012 #4 a2sdgui cam with the rom. links is better? CafeKampuchia said: Link2SD is the better route. Check out this guide: [TUTORIAL][Link2SD][ROOT]Updated! How to prep your SD card for it...Windoze Style Don't worry about the Linux swap partition found in the second post. Click to expand...
Caro332 Android Expert May 10, 2012 #5 I haven't tried a2sd but I love link2sd...I've got some 20+ apps and still have about 60mb free
Hendoe Well-Known Member May 10, 2012 #6 i used cwm to do the partition and was able to get 130mb.. it should have given me 1gb.... ill try links tonight Caro332 said: I haven't tried a2sd but I love link2sd...I've got some 20+ apps and still have about 60mb free Click to expand...
