i need help
hi i need help with my lg p350 im having trouble with the wifi connection itwont remember my home hub so threfore i cant have apps or internet what do i do :confused:
Welcome to Android Forums.
If you go to menu>settings>wireless & networks>Wifi settings can you see your home network listed? What happens if you try and connect to it? If it's listed but won't connect, try tapping on the name and selecting 'forget'. Then turn off Wifi and turn it back on, it should ask you for whatever passphrase you are using when it detects the network's SSID.
