Root I need help
mands386
Member
I need help my phone is charging all night and some parts of the day and the battery percentage won't go past 70 I've wiped battery stats but no luck last night I was at 55 I left it charging all night now it's at 47 can any one give me some suggestions I'm on midnight rom j by the way thanks for reading
Are you running Battery Monitor? You should. What's your voltage when it says 70% full? At the same time, (or over the next 5 minutes) what's your average current in mA?
what does battery monitor do, i got the app but i dont know how to use it
Open it up and hit some buttons. You should end up on a screen with some graphs. I like dual graph view myself, but you gotta play with the options and settings. It's also a widget which can show things at a glance.
Add the widget to a home screen, and it should start collecting data about your battery. It may have already collected some.
