Help I need help!!!
I have a Samsung SGH-I997 Infuse 4G and I tried to download a unofficial update which resulted in my phone giving me an error screen that says "Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again." When I downloaded Kies it did not recognize my phone and I had not made a recovery on Kies so When I go to emergency recovery I don't have a code to use. I think I might have permanently messed up my phone and really need some help.
Hello abdula!
I am sorry to hear about what is going on with your device:(
However, even though I am not familiar with it, I can move your thread to your device forum here if you like, where others that have your device can help:D
Samsung Infuse 4G - Android Forums
Can I assume you are not rooted?
Like I said, I can move your thread there if you like:)
Welcome to the forums abdula :hello:
Start Kies, click on tools then select Firmware upgrade and initialization. It will ask your phone's model number and serial number. You can find those numbers under your battery. Follow the instructions from Kies and hopefully it will install your stock rom.
