Help I NEED HELP
I was on stock on my sph-l720. (I should've stayed on this firmware.) I then flashed cm11. Later, I updated to cm12. I really want to go back to stock. I have tried using odin. My error is listed below. I then flashed a touchwiz based rom called the triforce rom. Odin failed on this firmware and kernel too. I then managed to flashed rooted stock with stock recovery. this will not boot. Regardless which firmware I am on, this is odin's error:
<ID:0/004> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> L720VPUFNG2_L720SPTFNG2_L720VPUFNG2_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/004> Odin v.3 engine (ID:4)..
<ID:0/004> File analysis..
<ID:0/004> SetupConnection..
<ID:0/004> Initialzation..
<ID:0/004> Get PIT for mapping..
<ID:0/004> Firmware update start..
<ID:0/004> aboot.mbn
<ID:0/004> NAND Write Start!!
<ID:0/004>
<ID:0/004> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
Please Help. I can show the give the names of each firmware if that would be helpful. If you can fix this, you will be my hero.
