I have google voice and the droid obviously and wanted to know if google voice uses my minutes or data. i have googled and i am finding conflicting answers
if you use your google-assigned voice number, it basically just forwards your calls from that number to your verizon number. you are not bypassing verizon at all. so yeah, it still uses your minutes.
also, you can sign up for your own invite here: https://services.google.com/fb/forms/googlevoiceinvite/
i got mine fairly fast.
Only true if u don't goin to ur gerenal settings and change it to show ur google voice number that's the key is for the google voice number to show up on the call logs not other poeples number and to do that u must hav changed that setting
but i'm almost positive that regardless of any settings, your calls are still using verizon's network, and therefore you are still using your plan (unless you use some sort of voip). someone correct me if i'm wrong.Ok you can save your minutes using google voice I been doing so first with the t mobile g1 with the myfavs plan and now I am with nationwide friends and family u just can't use the google voice app u hav to the google voice the old fashion way and hav a certain on with ur gv ok first of all u need to go to ur google voice account on the actual site either the mobile verison or on ur computer and go to settings then click on the general tab and from there scroll down to caller id this is were the magic happens it starts off with u change from display callers number to display my google voice. Now we u get a call u won't kno who it is on ur phone screen but it screens ur calls and tells u over the audio recording now next step since ur with verizon is to put ur google voice numbe on ur family and friends one of the 5 slots u got and to call and not use ur minutes u can not use the app u hav to manuall call ur gv number and then listen to the recording put ur password and then press 2 to dail the number u want to cal and ta da it is all free
believe it or not there in one "period" used in this post.
so let me get this straight when i place a call and i press send it asks me to use gv or not to use gv if i press gv it calls and uses minutes not data correct
I think the above posts are correct in saying that GV is free only if you designate your GV phone number as one of your five Verizon Family and Friends numbers, as I have. Thus, you need a 900 minute or higher plan. Were it not for that, I would have dropped my basic plan down to a lower minute limit.I have google voice and the droid obviously and wanted to know if google voice uses my minutes or data. i have googled and i am finding conflicting answers
oh i see.1 plan needs to hav my favs or family and friends depending which network ur on
ok i did not understand any of that.but i'm almost positive that regardless of any settings, your calls are still using verizon's network, and therefore you are still using your plan (unless you use some sort of voip). someone correct me if i'm wrong.
ok so ive set my google voice number as one of my faves so now when i call out from that number its free? and no minute usage?
