Sorry for the mistake but i can't get into download mode either because the phone wont turn on at all. Any other idea?lol, you dont use recovery mode to flash with odin, you use download mode.
its easy,
1. make sure you have odin set up and ready to go with all the files in the right places.
2. take the battery out of your phone
3. hold the volume up and down keys at the same time
3.b while holding the volume keys insert ur usb
3.c still while holding those volume keys with usb connected put in ur battery
4. wait for it
5. you should now see a triangle wit a android digging in the middle and odin should recognize your phone in download mode.
come to this place if you need any more help or pm me. other place is quicker!
when i charge the phone gets hot that's the only indication that anything is going on. I did some reading and found out it's called a hard brick but no clue how to undo it.i read somewhere that its best to keep trying. let your phone charge. does the phone register that it is charging? i read that eventually it will catch on. if its just from a voodoo mishap you should be good though as i have done this twice already by accident and by sheer impatience.
