Root I need to unroot!! HELP!!!
Ok ,, here we go
See were it says OPS ? Select that and go to the folder that you just unzipped . You then select the SPHM820.ops file
You then select BOOT and select the SPHM820_EJ06_boot file
You then select Phone and select the SPHM820_EJ06_phone file
You then select PDA and select the SPHM820_EJ06_pda file
After you have done all that >>>>> SELECT START and let it run .
Hello. Which one is better software, FE16 or the EJ06?
