Root I need to unroot...
Well, I took a trip around the world on ym couch and while at work the past two days while on a Sense ROM and with GPS on. Verizon is now sending me a new bolt, so I need to unroot my phone. Any suggestions or tips?
There's a guide in the "how to root/unroot" thread a little ways down the index page. Sorry I can't link it right now, I'm on my phone.
Yup, I saw and read that multiple times. I was just wondering if anyone had any tips. I will be unrooting as soon as my replacement gets here.
the most important thing is to make sure the md5s match when it says they should match.
if you still have drivers installed from when you rooted,you shouldnt have any prollem. just read thru the directions,organize yourself with the files,and post up if you have any questions before proceding.
if you cant get the downloads to work,try the other links on the multiupload page. they are still working for me using the "depositfiles" and "wupload" links :)
Thank you for the info. Now to research how to unroot the .9 update.
Do you have any links to those files? My replacement bolt arrived and I just tried dling the files but like you expected, multiupload isn't working.
EDIT: Nevermind, you ment for the dl options. I went to the actual site.
Here is a tip if no one else has already said it.
When you download files, RUU's, ROM's, Radios, tools, whatever, don't delete them when you're finished with them. Store them on a hard drive somewhere, in case you need them later. Sometimes they are huge files, and you don't want to have to download them again. Other times, they aren't as easily attainable later on when you need them.
if already a rooted phone, hidemyroot app will help you toggle between rooted/unrooted.... not sure it works for all versions....
