Also while the search feature on forums is great, and hopefully will be utilized - if someone comes here and asks a question, either answer it or don't. If you're going to suggest the search feature, be polite about it. Nothing irks me more than when I go to a forum, (and use the search!), then ask a question because I want some one on one with my problem, and get a simple "Use the search." reply. Suggesting it is encouraged, but don't withhold the answer because they don't.
