I really need help, bad. Please.
soupx360a
Ok, so when I tried to update my droid to 2.2 it crashed. Straight up crashed. It completely stopped working. My dad took it to the corporate verizon store and they fixed it up. I still have everything on my SD card, and all my contacts because it was backed up to my gmail. The only thing I dont have is all the apps that I had.
I CANT FIND A SINGLE APP THAT WAS ON MY PHONE.
I search the market for:
Advance Task Killer
Papastacker
Beautiful Widgets
Movies
etc etc etc
All the apps on my phone are gone and I cant ****ing find them.. and some of them I paid for.
Ive looked through a bunch of threads and cant find anything like this..does anybody know what to do?
Under settings --> Accounts, is there a Google account listed? If so, is it the same one you were logged into before?
If not perform a factory reset and log into the same account you used before.
Settings --> Privacy --> Factory data reset
Do this if the account in Settings --> Accounts and Sync is not the on you used before.
if there is no account there, add the one you used before and see if that helps.
I'm having the same problem. It has my gmail account there and the only options to sync are contact, gmail, and calendar. All my apps are gone and I can't find them in the Market.
You have to redownload all of the apps again one by one. You wont have to pay for the ones you already paid for. Next time back them up if you want to skip this step. Goodluck.
