Help I really need some help with my soft-bricked tablet!!!
Poke4Ever10
Hi, could somebody PLEASE help me through process of unbricking my tab? I've gotten so far, but I'm stuck and don't know what to do!
What I have done:
  • Download Odin 3.09 + Odin 3.07
  • Download (and re-download) the latest USB Drivers
  • Used different ports and cords, but only one seems to get me anywhere
  • Download several firmwares, and I think this one is the only one that gets me close: N5110XXDNE1_N5110XACDNE2_HOME.tar.md5
  • Tried flashing with the firmwre set to AP, and had Auto Reboot and F. Reset Time selected
This is the latest log I got:
<ID:0/003> Added!!
<OSM> Enter Cs for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please Wait..
<OSM> N5110XXDNE1_N5110XACDNE2_HOME.tar.md5 is v
<OSM> Checking MD5 finished Sucessfully..
<OSM> File analysis..
<ID:0/003> Odin V.3 engine (ID:3)..
<ID:0/003> File analysis..
<ID:0/003> SetupConnection..
<ID:0/003> Initialization..
<ID:0/003> Get PIT for mapping..
<ID:0/003> Firmware update start..
<ID:0/003> SingleDownload.
<ID:0/003> sboot.bin
<ID:0/003> NAND Write Start!!
<ID:0/003> FAIL!
<ID:0/003>
<ID:0/003> Complete(Write) operation failed
<OSM> All threads completed. (succeed 0 / failed 1)
Can anybody help me out?
P.S. I have NO idea how it got softbricked. All I know is that I came home from highschool, and my tablet was in a loop. I have not installed any ROMs.
Thank you in advance!:D
Try installing another ROM through Odin, i.e Samsung Stock. That should fix your issue.
I don't have any idea where to find one. Could you maybe give me a link as to where I could download it? So far I've been trying to use the Canadian version from Sammobile.com.
Ok, so I downloaded the bootloader and flashed it onto my tablet, and it reset. I turned it back on and it was still in a loop, so I tried flashing the firmware again, but I got the same Nand Fail message.
Oh wait, I downloaded the first thing, the modem/bootloader thing? Should instead follow the second link (the one that leads to Mega) and flash that?
Ok, so I downloaded the CivZ-FlexNote8.0_KK-Rev2.1-N5110_signed.zip file, and Odin won't detect .zip files, so I extracted it. But now, when i try, instead of flashing the entire folder, it just opens to the other folders until i select a single file. I'm really confused. And also, on Odin, I should keep using AP, right?
Odin won't let me flash .zip files. If i put CivZ-FlexNote8.0_KK-Rev2.1-N5110_signed.zip into the file selection, it fails instantly. I thought maybe just Odin 3.09 wouldn't let me flash it, so I tried 3.07, but no dice.
Okay, so I ran the initial download, it turned into another Odin type launcher, and I connected my tablet and it showed up. I didnt know if there was anymore to it so I started and it showed,
sboot.bin..
All threads completed (succeed 0 /fail 1)
And it came up with a FAIL.
