SamsungAdmire
Android Expert
Got the 2.3.6 update. Everything is working 100%. My Question : Does the ACSyndicate Clockwork mod recovery work fine with the 2.3.6 update? Would like a response.. Thanks!
how did you upgrade to 2.3.6
http://androidforums.com/samsung-admire/454073-regarding-2-3-6-update-metropcs-solved.html
the download is there.
NOTE: You won't have data/ mms / market wont work so unless you know what you are doing you can do this unofficial update.
The thread tells you what to do to fix data connection, mms etc.
That's for fixing data and mms and market. What are the steps and files please. Or mabe system dump.kudos
