Root i root inspire 4g my brother pull the usb cable big problem help
jojosabz
i root my htc inpire 4g using aahk i ddnt realize in the middle of rooting my younger brother pull the usb cable and now my phone cant boot up can anyone help me please.... ive already use mini-adb, is there any posibilities to fix this??
does the phone still boot into bootloader? if so,do this and list the output:
first download and install these drivers: revolutionary drivers (mirror)
then,download this small file:
mini-adb.zip
-unzip it,and place the unzipped folder onto the root of your C drive(not inside a folder)
-open a cmd window(with win 7,click start bubble,type "command" or "cmd" in hte search box)
-now change to your mini-adb directory(assuming you didnt chagne the name). type in the black cmd window that opened on your PC:
cd c:\mini-adb
-pull the battery in your phone for a few seconds. hold volume down,then power. hold them both until you see the white/colored writing hboot screen
-select "fastboot" from the hboot menu with the vol rocker/power button
-in your cmd window type:
fastboot devices
it should output your phones serial number. if so youre good to go. if not,youre apparently having a driver issue. i usually recomend these drivers from Revolutionary: modified htc drivers download and install the drivers(you should just have to run that file). afterwards,unplug your phone,plug it back in. make sure its in fastboot. as soon as you get a result from "fastboot devices" your ready to procede to the next step.
-in your cmd window,type(or copy/paste,is much easier):
fastboot getvar all
-copy the info that outputs here. right click in your cmd window,click mark,highlight it all in white. hit enter. paste the info here. it will help us know which ruu for you to run. :)
you probably just need to an RUU.
assuming you are on the latest build(with sense 3.0) then you just need to put the phone into fastboot,then download and run this utility on the PC:
Shipped ROMs
plug in the phone when directed :)
if you are on the previous release build,you can use this RUU:
Shipped ROMs
