I rooted with the wrong PDA
hyperized
I am new to this rooting stuff and I believe that I have done something incredibly stupid and wrong.
I have the Samsung Galaxy S2 i1777 from AT&T.
Today I tried to root it using various online sources.
I used odin, and for the PDA section, I think that I have put in something that is not for i1777 but instead is for GT-I9100 because after the phone is rebooted, two of the four buttons stopped working. I know that i9100 has only one button while i1777 has four.
I decided to factory reset it. However afterwards, the buttons still wouldn't work. Also wifi stopped working.
I found two new apps on the phone, one is called SuperSU or something and the other is called CWM.
I clicked on CWM and selected recovery reboot.
Now my phone is stuck on a page that has blue and yellow words all over it.
there are a few options in blue text which say:
"reboot system now"
"apply update from sdcard"
"wipe data/factory reset"
"wipe cache partition"
However I am not able to select any of them because the keys for control are: "Enter: OK Key. Select : Vol UP / Vol Down"
I can scroll up and down on those selections but I cant enter because I dont have an OK key.
I am guessing that it is something that i9100 has?
Now I really really need help.
I just want to reset my phone to the way it was before.
Can anyone please help me?
put the phone in Odin mode again. With USB plugged in hold up/down volume and power until the warning screen shows up.
If not you'll need to score a jig that forces the phone into download mode upon boot up.
i got into Odin mode. but i dont know what PDA should i use.
