I set a default contact number... how do I undo?
pkulak
Member
So, I selected "remember this" when I was sending a text to a contact, because it was the mobile number. Turns out, that set the number as "default" for the contact and now I no longer get to choose which number to use when calling. How can I got back to not having a "default" number?
It isn't the most intuitive, but you can delete the number that you made default for the contact and then add it back. After you do that it will ask you which number to use again.
Also if you just want to change the default number you can long press on the new one and choose "make default."
The original question still hasn't been answered. If this is a feature request than I hope that someone that knows how to submit Android features reads this.
