Root I think I'm Bricked Plz Help
Hey, I have a Zte Force that i think is bricked. Well i had First rooted(i forgot what method), Then installed CMW-based Recovery via Terminal Emulator. I had tried another rom and the phone got stuck at the Big Android Man. Note- I successfully installed DroidSmith. Now I've formated every thing, tried new roms, even tried using a nandroid restore off the internet. Every time i boot it stays at the android man for a sec,Then shows like some wierd screen then goes to cwm in a matter of secs. I dont know what to do can I get some help please, Thanks.
if it can get to recovery then you should be able to flash the b13 update and that'll restore your phone to stock.
ok well this is a question better suited for the all things root section, and i cant see the video but as long as you just flashed a bad rom for this device you should be able to flash another one in cwm, do a factory reset, and boot right up. if you cant, it might be the recovery ive heard of people having issues with versions of cwm other than the original one. check the all things root section for the older version i use it should be there somewhere
now, if you flashed a rom from a device other than this one, then you are likely done for, but i would think that would break recovery as well...
tried new roms,.
When you say then you "tried new roms" Makes me think you flashed a rom not for this phone because there really isnt any roms for the Force except for the 2 in the root section. I wont spec to much more but I think it could be fixed if you can get into recovery. good luck with that.
