Root i would like to help out
could someone like give me a small tutorial on how to make roms and themes i would really like to help out in anyway i can if not at least show me a tread that maybe someone already made on how to make roms and themes i would really appreciate + i got alot of time on my hand right now so id like to use it on something productive :)
Sent you a private message, but to start you might want to use kitchen, UOT Kitchen. Kitchen, you can use root explorer to copy the /app/systemUI.apk, and the /framework/framework-res.apk files to your sd card then put them on your computer.
Use kitchen to change a few things, then upload those two files, and then when kitchen is done and you download your new files you can use root explorer to replace the originals. If you want to do more then refer to the private message.
Use kitchen to change a few things, then upload those two files, and then when kitchen is done and you download your new files you can use root explorer to replace the origionals. If you want to do more then refer to the private message.
can i use root explorer im kinda scared to use any file manager and then have my phone bricked
and i kinda dont get what you mean like explain to me what can i change pretty much and is there a lot that goes into changing them
yes you can use root explorer to copy the files to your sd card, then put them on your computer leaving the original on your phone. Edit the files with kitchen, or you can edit the images yourself and then put on sd card and use root explorer to replace originals with the ones you made. If something doesnt work right just flash one of the odin tars that are posted in the forum and your phone will be back to normal.
If you read the pm I sent you all the editing is done on the pc on copies of originals, not on the phone its self.
