i9300 and i9305 same LCD Screen Touch Digitizer Assembly?
This is a hard one. My guess would be yes but please do the research (wish i could help more lol)
Do you see any listings for an i9305 digi' or any saying i9300/i9305?
Thanks for trying to answer this :) Very few listings have them both together as i9300/i9305 .. the majority have them listed separately, so it's difficult to tell.
I know there are some differences between the 2 phones (the i9300 has 1gb of Ram, while the i9305 has 2 and the i9305 has a newer Android version), but I can't tell if these changes have anything to do with the LCD + Digitizer assembly and not sure where to find this out :mad:
Anyone?
Cheers.
Best to ask samsung. Yeah the i9305 also has a 4g antenna so there could be lil changes to fit these things in. id ask samsung for the part number for both just to see if theres a difference. Good luck with not ******* it up when u do find the right part lol :p:beer:
Hello, The LCD Screen Digitizer Assembly for Samsung Galaxy S3 i9300 and i9305 is totally the same ! BUT, please not but the frame (Front cover) is not the same. If you want to only replace the lcd display and front touch glass, then i9300 and i9305 are the same. However, if you want to replace the lcd screen digitizer with frame together, then i9300 and i9305 are not compatible. Because the frame structure is not identical. Got it now??:)
