Rico ANDROID
Android Expert
Im gettn the "i wanna new device with ics" bloos out here! I might have to spring for an htc really soon!
Your mistaken with ICS you have the option to have however many screens you want.Just click home until all your screens show and long press the one you want to remove and drag it to the bin in the top right corner.I was using Golauncher Ex before i upgraded but love using sense with this new ICS Upgrade.
Hope this helps!![]()
This is not an option in Sense.It uses carousel animation instead of scrolling wallpaper.Only way to have this is to go with a launcher that supports scrolling wallpaper.Thanks, now..what about a scrolling wallpaper???
The ICS RUU already has the wifi hotspot connection.Under menu/settings/more.../tethering & portable hotspot.I too installed the ICS RUU this morning. I must have read everything ten times, and then backed everything up five times.
Very easy simple install. Still making tweaks, however I defintely like the interface better. Looks like I will have to go with a WCX ROM though for the wifi hotspot enablement. I now have all the SDK and java software installed, next thiing is to root after I fully understand the process. Back to more reading.
Its times like these that I miss my Windows Mobile phone (Only because I knew how to fearlessly dive into it).
No i do not.Looks like rooting and another ROM is the way to go for what you need.Yes it does, however it is blocked unless you add a tethering plan. Unfortunately AT&T will not allow me to keep the unlimited plan with their tether plan. PDA NET still works with a cable, however I need the wifi to work for a tablet and IPAD in the car for the kids.
Unless you have some exploit or work around I have yet to find?
No problems here.Have you tried restarting your phone?My data keeps turning off. Both WiFi and apn keep turning off.
Android optimizes each time you restart.
Also go to menu/settings/usage and make sure Set data usage limit is not checked and mobile network is turned on under this setting.
Im at a loss on this problem.Did you try pulling the battery?Data still timing out
Does my phone have to be rooted? S-off? or bootloader unlocked to install this?
Chall80 said:Ok, so here we go....
First, go to this link and download the RUU(Rom Upgrade Utility) http://goo-inside.me/devs/pirateghost/vivid/RUU/RUU_HOLIDAY_ICS_35_S_CINGULAR_3.26.502.52.zip
Second, you need to use HTC Sync to sync any data that you want saved.
Third, you need to connect your device to your computer, and set it to "charge only". You need to make sure that you have "USB Debugging Enabled".
Once you've enabled USB Debugging, and connected your device using the "charge only" setting, Double click the RUU file.
- From the Home screen, press the Menu key.
- Tap Settings.
- Tap Applications.
- Tap Development
- Tap to check USB debugging.
From that point on, it will prompt you for a couple things, but there are no options or choices to make. Its bulletproof.
THIS OPERATION WILL COMPLETELY WIPE YOUR ONBOARD DATA, AND RETURN YOUR PHONE TO "OUT OF BOX" CONDITION. It will have Android 4.0.3, and Sense 3.6
This is an AT&T release and does not void your warranty, unlock your bootloader, gain access to the root folder, or remove AT&T bloatware. This is perfectly legit for those who don't wish to mess with root. An RUU is the manufacturers method for upgrading phones.
I have screenshots, and just don't wanna mess with uploading them(too much of a pain). If you wanna see them, PM me and I'll email them to you.
This is painless and so worth it!!!
EDIT: This does not wipe your SD Card
No you just install it like you do any AT&T Update.The directions and link to the Ruu ROM are below.Just follow chall80's directions after downloading the ROM
will try once my phone battery reaches 50%Unless you found an announcement from AT&T or HTC that it will be Sense 4.0.I don't believe it will be Sense 4.0.From what i understand that's a rumor.I am trying to find out for sure thoughI'm going to hold off.. They are doing upgrade for many of the "international" Vivid.. and some have sense 4.0! It cant me much longer till an official release....
....... ...... right.. hahah
Some people are also saying this works to get the update with no ROM's or Hacks.
I performed a system update yesterday by dialing *#*#682#*#* after it was done I woke up with ICS and sense 3.6
ICS updated, no hack nor rom - Android Forums at AndroidCentral.com
If it works, it is basically just pinging att's system to send you the "user-friendly RUU". I don't believe that wipes all your data...although I'm a firm believer in a full wipe upon any system mods...its just good practice...
