Icons...suggestions please
KevTN
Hey folks...I am enjoying my X. does anyone know if there is an Icon pack for Motorcycles. I ride a goldwing and do cross country trips. it would just make things a little more personal.
Thanks
You could do an advanced image search with google, the icon size you need to find is 84x84.
I don't even worry about size when looking for a picture to use as an icon, the system will resize it automatically. Just figured out how the custom shortcuts thing works, so making new shortcuts on my desktop with red/black icons. I downloaded a theme and some icon packs, but there isn't an icon for everything, so I'm fixing the rest myself!
The only drawback with not picking the right size is that if they are too small they will look bad when the system re-sizes them.
OK, you got me, that is true, blowing up small stuff never looks good. So far I haven't had problems finding stuff over 200x200 to use, and that stuff will look fine shrunk down.
do a search for Motorcycle Icons on google, click images, then on the left where you can filter for image sizes, select "icons", email them to your phone, then use Launcher Pro to pick which icon you want for which shortcut on the home screen. I picked up some pretty neat icons that weren't designed for phones but look amazing...
