kandie76544
I researched my battery problem and one suggestion was to remove the battery, plug phone up to charger. let it stay like that a few seconds then replace the battery and immediately replace the battery. this seemed to work at first. the phone came on and stayed on and was charging. all the sudden it started draining it even faster, I was litterally watching the % go down. then I came across this site. the best suggestion I found was to clear the cache. I've done that. (when you restart the phone does seeing scrolling text mean you got it right?) if so how long does that take? my phone is at 17%, the highest it's been in a while, does this mean my problem is fixed and what are some other options if it's not?
