TheMortallyWounded
Please post anything you know about "your" current build, either leaked or OTA, about ICS for Rezound. We can compare and see what we want to do.
I would like to know the difference between .10 and .12... since I succumbed and installed the leak (.10) yesterday. I see varying opinions about whether I'll even have the option to install the OTA (if and) when it comes out.
Android version
4.0.3
HTC Sense version
3.6
Software number
3.14.605.10 71ORD
Kernel version
3.0.16-gd0049f1
htc-kernel@u18000-build-144#1
SMP PREEMPT
Baseband version
1.22.10.0421r, 1.22.10.042r
Build number
3.14.605.10CL372320 release-keys
Browser version
WebKit/534.30
PRI Version
1.16_002,2.10_002
PRL Version
15130
ERI Version
5
Whew! Hope that helps you with whatever, TMW.
Actual differences in features, things you may have noticed... I didn't have a chance to elaborate before. My bad. I have .10 and want to know what has been improved or reduced in .12 as people get it installed one way or another.
For example, one guy who received .12 OTAtells me that Developer Options is STILL available on his, which is good to know, because I figured it would have been removed from the .10 leak before the rollout.
I'm also curious to see if Market allows previously blocked apps like FoxFi are now available, since the FCC ruled against Verizon's blocking free WiFi tethering apps. Things of that nature.
In general, what changed between .10 and .12? Or an official.changelog would be very helpful.
