Wildbill21
Phonedog.com has confirmed ATT people will get ICS on July 10th! Thank you Jesus!!!
Ditto here.I just checked with kies and I got my update!
How do I do that?
I was reading through Android - Introducing Ice Cream Sandwich and it mentions 4.0 has visual voicemail. Does the Note update include visual voicemail does anyone know?
It appears it didn't come with it but I found a copy in my dropbox folder and was able to install it no problem.
I'm sure, as with the SII release, the Dev's will use a sytem dump to post up a .tar file with root already. If you have the patience just wait it out.So is it even worth unrooting, going back to stock and upgrading to official ics?
I am new to android how did you get it on your Note? Is it an app?
