ICS features missing?
Liquos
Just wanted to know - is the version of ICS taht the Galaxy S2 Skyrocket gets 'ICS lite' or something? It seems to be missing a lot of features that ICS should have, like taking screenshots by holding the volume + power button and making program folders by dragging icons on top of one another.
Really? It's missing the program folders feature? I really like that on my Asus tablet and was looking forward to having it on my phone. Convenient to, for example, put all my news apps under one "News" icon and not waste so much screen space with individual icons.
FWIW though, the mfrs tend to put their own specific launcher screens on top of Android (e.g. "HTC Sense"), and this might be what you're seeing. But now I'm not in as much of a hurry to upgrade!
Yea i was thinking the same thing,It doesnt seem to have alot of the features i saw on youtube and read about,Example the lock screen doesnt have the camara feature,I was wondering if i should reinstall the update?..
The screenshot works but you have to hold the "Home + Power" buttons.
I don't think reinstalling the software will improve things. It is what it is until they release another update or a patch.
This sounds like the Jellybean update, not ICS, not sure though, I have to rewatch the videos
"An improved Picture Gallery widget lets you look at pictures directly on the home screen" also
Also, in All Apps launcher, you can now simply drag an app to get information about it or immediately uninstall it, or disable a pre-installed app
where are these?
Just so that everyone knows how Android works and whats new with ICS:
Android - Introducing Ice Cream Sandwich
Keep in mind that some features are different on many phones. Otherwise they would all be the same. The company, (In this case being samsung) makes changes and enhancements to there phones to make them different from the competition. Some additional features are removed, to keep the phone fast, others are added onto the android version to give it more unique features then the other phone makers. Android is open source, giving users choice. If you want a pure google android version unmodified, pure google, get the galaxy nexus.
Here is what we have of ics features that were included:
1.)
Refined, evolved UI
2.)
Resizable widgets
3.)
Quick responses for incoming calls (notice how we had this in GB, added feature at the time.)
4.)
Swipe to dismiss notifications, tasks, and browser tabs
5.)
Improved text input and spell-checking
6.)
Powerful voice input engine
7.)
Control over network data
8.)
Designed for accessibility
9.)
People and profiles,
Unified calendar, visual voicemail (already had visual voicemail through ATT app.)
Rich and versatile camera capabilities
Redesigned Gallery app with photo editor -(already had this in gb. Seeing the trend?)
Live Effects for transforming video
The powerful web browsing and everything else below it we have. We have face unlock and everything else. We have the app disable. Go to settings-applications-all. Choose the app you want to disable. Note that not all apps can be disabled, and if your phones starts behaving odd, re-enable the app. I suggest disabling one app at a time and use your phone like you normally would. If you don't have any problems go ahead and continue disabling other apps.
The reason we do not have the drag and drop apps, is because it is samsung's launcher. Not androids. So its there app, not androids. This is why the layout and everything is different. Everything I have listed I have as features. We do not have the lock screen actions as samsung customized it a bit.
In a sense, every version of android other then Galaxy devices is kinda like a "lite" version. Features are different for a reason. Another thing is some phones cannot handle certain features. Such as a phone getting ics but lacks the face unlock feature as the phone does not have a front facing camera, etc. Hope this helps clear things up.
for the screenshots, you need to hold power button + home button at the same time (just like before) but now you have to wait a little longer for the screenshot to happen.
