My unbranded and unlocked UK Sensation is telling me that I can update to ICS. But I have been readings about lots of problems. So should I update or not? Are the improvements worth the hassle or should I wait until the bugs are fixed.
I need to be able to continue to send and receive emails and play music (using MixZing). I also need to make sure that the following apps and/or widgets work properly:
If you are using any of these with ICS I would be really grateful if you could confirm whether or not they are working OK. Also will I be able to restore the apps I have backed up onto the SD card using Astro please? I know I can redownload from the Market (or whatever it is called now) but one or two are no longer available and with some others I prefer the older versions.
Thanks for any help you can give me
- Sygic sat nav,
- Train Times
- 3G watchdog
- London Tube Status
- ezPDF
- Dolphin Browser
- Agenda Widget
- Swiftkey
