destinykymm
Hello all. I updated to ICS yesterday. After my search and gallery would flash and close down, I decided to do a factory reset. All that seems fine now, but before that, and now, I'm having trouble recieving mms. They don't automatically download, even though I have that option set, and half the time it gives me an error and won't retrieve the picture. Any ideas and fixes? Also, data options are different. For me to afford dataI'm on a 300mb a month plan. On Gingerbread I always kept background data off except over WiFi so I don't go over my limit. Can I still do that on ICS? I've restricted my data, then used the menu button to also check the restrict option there. Is that the same as disabling background data? Thanks for any help.
