johnny424
Android Expert
I found this sweet ICS Boot Animation over on XDA..It was edited by Diliban to work for MDPI devices..I did not create this and i am only sharing a good find with good friends
....So check out his original thread over at XDA ..Heres the link for the XDA thread.. http://forum.xda-developers.com/showthread.php?t=1295277..select this to download --> http://forum.xda-developers.com/attachment.php?attachmentid=744294&d=1318152057..It cannot be flashed..For anyone not sure of changing your Boot Animation.. The instructions are in his post..Or use mine...Be sure to make a backup in CWM beforehand incase somehow you screw something up
Using Root Explorer
Download Dilibans bootanimation.zip on to your sd
Using Root Explorer extract bootanimation.zip
Mount system R/w
Move current bootanimation.zip to pc or new folder on your sd (if ya wanna save it, otherwise delete it)
Go to folder where extracted ICS animation has been moved, long press, select move
Move the ICS bootanimation.zip to System/Media and paste
The new ICS boot animation MUST BE NAMED bootanimation.zip
Mount system R/o, exit Root explorer , and reboot
Thanks to Diliban for this edited boot animation...ive tried many...this is the best ive come across
Idea of what it looks like (The actual boot animation will be much brighter and clear..this is just a google image..to give people who arent all ready aware of what it looks like)
If you wanna go for the whole ICS theme you can also get an app off the market called Super Status bar..with this app you can completely redesign your notifacation bar...or use a preset theme..which would be the ICS theme..they have many..it is free so expect a few adds !.....I would reccomend the Pro version..
And if you wanted almost the whole phone themed out in ICS...Buy ADW EX and theres a ICS theme for it called ICS Sqrd
Using Root Explorer
Mount system R/w
