Im new here, and ive been looking around and i was wondering wether cm7 or cm9 was better, i thought 9 would be better since its the higher number
I mean i'd like it but i dont need it, is there a big difference between 7 and 9?Do you need the camera to work? If so, you'll want to stick with CM7. CM9 is still in beta at this point, but with the exception of the camera it works very well.
Alright thanks, im gonna try cm9 first and see how it isMy suggestion would be to do a Nandroid backup of your current setup and give both a try for a short time and see how you like them. Personally I think CM9 is a big step over CM7 but it still has some issues to work through being that it's still beta. The biggest problems with CM7 are that HDMI does not work, the phone will not go into deep sleep with either Wi-Fi or Bluetooth enabled, and if you enable both Wi-Fi and Bluetooth together it pegs the CPU at 100%. Also, the GPS on CM7, while much improved over previous versions, is still not as good as it is on the Sharp and U9000 ROMs.
With that said, I'm currently using CM7.2. I tried CM9, Sharp, and U9000 ROM's and they all had issues for me with the way I use my phone so I had to drop back to CM7.2.
