Help ICS Photo Gallery Problems
zoneguy
Just upgraded to ICS on my S2, The problem that I'm experiencing is when I try to add a Photo Frame Widget. The photo gallery NEVER loads the pictures so I can select one for the frame.
Is anyone else having this problem?
Any solution?
No, that is one issue I haven't had, I've had the camera crash on several occasions and lock up the system for a few minutes... I had to pull the battery to get out of that. Maybe backup your system and reset it all. Hopefully for you it mostly works well, some are reporting good luck. For me it started laggy and just got worse. Good luck!
