LowEndGeek
Android Expert
[MOD NOTE]
Thread closed at request of OP - this ROM is no longer supported.
[/MOD NOTE]
Here is the first public build of Paranoid Android for the Optimus Elite, it's based on paranoid android 1.5a
Credits:
Paranoid Team for the rom
Phenomx4 for ICS
Starkraving for testing a previous build
The entire community
You can see screenshots HERE
What works:
All main things work, just working on getting the PA specific things fully working
What doesnt:
# NFC doesn't seem to be in the menu at all.
# Setting status bar density freezes the phone, requiring a battery pull
##### Recommendations ######
Best settings for the keyboard is DefaultUI - Stock DPI and it should work just fine.
Still need to adjust the pad.prop
When you first boot it is recommended that you open paranoid backup and backup your settings just in case
## Next release
I'm trying to get 1.6 or possibly 2.x for the next update. I actually didn't realize this was 1.5 I thought it was 1.6
Downloads:
paEliteSEP20-1 Virgin
md5sum 9b2ae88004ec22db91964149c2690f5d
Install the regular ics gapps
[/MOD NOTE]
Credits:
Phenomx4 for ICS
What works:
What doesnt:
## Next release
Downloads:
