Root ICS ROMs for R800x
fuhrl
I finally decided to try out some ICS ROMs for my r800x after unlocking my bootloader a few months ago. I'm pretty impressed with what I've tried so far but they aren't without their (minor) issues. a couple of the roms, PlAyOSP and another that I can't remember the name of right now, has an issue playing bluetooth audio and with the CM9 RC2 that was just released, I can't get the wifi to work, didn't try the bluetooth audio, as soon as i found the wifi didn't work i switched back to PlAyOSP. Every ROM seems to have issues with the analog pads working correctly. So, I guess I should get to my question finally: Is anyone else using ICS ROMs for their R00x and are you having any of the same issues or is there a fix somewhere that I'm missing. I've tried researching as much as I could but the threads over at XDA are all over the place and I can't seem to find any useful information. I'm sure Paxchristos would have some answers for me but it seems like he's been MIA from this forum for a good while now. Thanks in advance for any info or suggestions!
............ Is anyone else using ICS ROMs for their R00x and are you having any of the same issues or is there a fix somewhere that I'm missing. I've tried researching as much as I could but the threads over at XDA are all over the place and I can't seem to find any useful information. ......!
I'd love to know the same. Working on unlocking my phone now.
dbR
wow. it's been a while since i posted this! Since then I've tried just about every ICS ROM for the Xperia Play. While there are still kinks to be worked out (mainly touchpad control issues) there are a few ROMS that are worth trying out. I would suggest the CM9.1 FreeXperia Project found here: http://forum.xda-developers.com/showthread.php?t=1447542
for me, it's given me the least amount of issues and pretty much everything essential works (again, touch pads are still a bit of an issue). If you have any questions I will try to answer them the best I can.
