that's if we get Dev support.
that browser is a bit different compared to the actual ICS. It does look similar to ours though which ours is 2.3.
I tried this weekend to install the ICS update for the honor from the actual chines website. downloaded the zip file and google translated the 7 page Chinese PDF, it looked successful when i went to update from sd. It downloaded part 1/2 but when it came to 2/2 it automatically failed.
I wouldnt mind it in white, never had a colored phone other than black and dark blue.
yes it is and in the PDF file it said something that not to try it if it has 'broken root' due to it getting bricked.
Honestly, I would be scared to try that. The Honor has a GSM radio and the Mercury has a CDMA radio. Messing with the radios is probably the easiest way to brick a phone. You probably wouldn't brick it, but I wouldn't chance it just to see what it looks like.
