I'm currently trying to root my WFS and I've got as far as trying to disable S-ON and trying to get my id token, but failing badly.
Not really worried about S-on for now but I want to know how to get the token?
I'm using fastboot but the problem is that it doesn't have the command "get_identification_token" available to it. Is there another way or do I need to get another version of fastboot? (Link?
I'm using CMD, cd'ing the directory to C:\Android\root (the folder where fastboot is stored on my pc), punching in the command "fastboot oem get_identification_token" and getting invalid command error. I type in "fastboot oem h" to view command list, and this command doesn't exist apparently?
I'm completely new to Android, and this place looks cosy
)I'm using CMD, cd'ing the directory to C:\Android\root (the folder where fastboot is stored on my pc), punching in the command "fastboot oem get_identification_token" and getting invalid command error. I type in "fastboot oem h" to view command list, and this command doesn't exist apparently?
