xPureEvilx
AreaRom Install How To
(Read all of this!!! Don't try to be "smart" and skip ahead!!!!)
Here is what to do:
1. Download the AreaRom Odin
2. Unzip it to a folder on your computer
3. Hook up a USB cord to your phone -> Computer
4. Download AreaRom v2.3
5. Place the AreaRom2.3.zip on you phones SD card
(dont unzip it, just download and transfer it)
6. Shut your phone off
7. Hold - Volume Down + Camera + Power (hit power last)
8. Your phone should now say DOWNLOAD
(Yellow dont show good on here with with background)
9. Open the Odin.exe we unzipped to your computer
10. Put the .OPS file in the OPS slot
11. Put the Boot.tar in the Boot slot
12. Put the Phone.tar in the Phone slot
13. Put the PDA.tar in the PDA slot
14. Start the Odin
15. Wait for your phone to restart
(in the rare case it doesn't, give it about 5 mins then restart it yourself)
16. After your phone boots up, shut it off
17. Hold Camera + Volume Up + Power (hit power last)
18. You should now be in recovery mode
a. Press the Volume buttons to navigate up and down
b. Press camera to select stuff
c. Press power to go back
19. Select: Install zip from SDcard
20. Select: Choose zip from SDcard
21. Find: AreaRom2.3.zip
22. Select: AreaRom2.3.zip
23. Select: Yes - Install AreaRom2.3.zip
24. Wait for your Phone to restart
----Your not done, keep reading!------
25. Wait for you phone to boot back up
a. This my take 5 mins the first boot, this is normal...Dont Panic!
26. Hold Power button and select recovery
27. Wait for phone to boot into recovery
28. Select: wipe data/factory reset
29. Select: Yes -- delete all user data
30. wait for it to be done
31. Select: reboot system now
32. Phone will boot back into recovery
a. We have no idea why it does this
b. Don't bother asking why
33. Select: reboot system now
34. Your Done, and if you did everything in this order it worked!!
p.s.
This is how you install any versions of AreaRom v2.x other then the name of the zip on your SDcard changes.
Thank You,
PureEvil
