Root If i could get some help then say hi to DEV :D
Hi i am aaron and i am pretty proficient in Java and Java Script but i have never tried anything androids way even though i know all so much about android and cellular info and phones i know a lot of stuff like i could tell you just about everything on any carrier phonewise and types of coverage such as Ev-Do rev.a or 0 or Hspa and i know a lot about android and metro and the actual phones you ask me about a phone i can tell you almost all the specs on it from processor too screen too what kind of cellular signals it uses for data and stuff. now i have never tried anything android but if its coded in Java i think i could get the hang of it real quick i just need a dev to help me a little ive asked Unforgiving about a few things (not about a release date for cm7) but like what phone is he porting it from (so i could start porting one myself) and how dificult is it too make a Rom and how to get started i know i have to take the android source code and make it too a zip folder with a META-inf folder in it and that commands what to do with the system folder but i dont know how to get started creating the rom and working with the source code cause ive never tried and if i do well in the admire (porting cyanogenmod 7 ) i might make something for other phones (weather it be cm7 or just a rom ) and maybe something for the Lg Esteem which i am getting in jan but i have a optimus m and an admire and ive been looking around and there is no mods for us as of yet i would like to change that but i need help so if your a dev PM me for some info and maybe we can get started :P thanks
Try checking out the cyanogen website, they have a good dev community solely for making cyanogenmod roms.
your background with java will help when it comes to editing smali n thats about it. your gonna have to learn c when it comes to editing and building from source.
I think you could do fine if you sharpen your learning.
C, Java, and knowledge of the Linux kernel are all very important things when it comes to the Android OS. I wish you the best of luck, you've certainly got more Willpower than I do. I can't be arsed to learn the Android OS, so I'll be happy with being a gopher to real Devs.
