if i revert back to stock, will i lose the 2.15 radio update as well as root and cyanogenmod? i just want to make sure that if i decide to root again i will not brick my phone as i have read that applying the same radio update twice will do so.
I don't think you can keep the radio if you go back to stock unless you apply it again after going back to stock. You will loose root and cyanogenmod and root but you can root again while staying stock.
