Accessories IF someone went with the 3500 battery what case fits it?
Fine69
As you all know the Incredible is fragile without a case. Most smart phones other than the I1 on nextel so what case fits the Incredible when you go with this large of battery and back extension? I may have missed the links to cases that fit.
I have a innocase surface II case and holster for the original back (1300 mah).. I want the same kinda thing for the 3500 battery.. does any ones know of a solution to this yet.. Seido said no go for now when I emailed them.
Just today I received the Seidio 3500mah battery along with their Innocase Extended made specifically for the Dinc using their battery.
It's available on their online store (seidioonline.com).
Fits like a glove.
There are pictures on Seidios online store.
I used a Black Silicon Case from Verizon and cut out the ack and that works very nice , I know others have used hard case but I don't own a dremel to try and modify that
Fits like a glove.
I bought the 2150 battery for $30 with corporate discount and 30% off. I have not used it yet since I do not have a case. Would love to know if the extended case works with the 2150 battery. Has anyone tried it?
