Root If you've updated to M050 and rooted
Doctoror
No longer needed, the ROM is here
[ROM] Jelly Bean 4.1.2 (M050)
Thanks to brandennj.
Old message:
These commands will write the files to Internal Storage.
After written, upload them so I can download and create M050 update for myself and guys with CWM recovery.
Copy-paste these to adb shell window so no typos are made.
Important ones
Code:
su
dd if=/dev/block/mmcblk0p1 of=/mnt/sdcard/modem.img
dd if=/dev/block/mmcblk0p7 of=/mnt/sdcard/boot.img
dd if=/dev/block/mmcblk0p13 of=/mnt/sdcard/system.img
I woun't probably use these, so if you're not lazy enough I would like these as well just in case.
Code:
dd if=/dev/block/mmcblk0p19 of=/mnt/sdcard/recovery.img
dd if=/dev/block/mmcblk0p5 of=/mnt/sdcard/aboot.img
dd if=/dev/block/mmcblk0p8 of=/mnt/sdcard/tz.img
dd if=/dev/block/mmcblk0p6 of=/mnt/sdcard/rpm.img
dd if=/dev/block/mmcblk0p2 of=/mnt/sdcard/sbl1.img
dd if=/dev/block/mmcblk0p3 of=/mnt/sdcard/sbl2.img
dd if=/dev/block/mmcblk0p4 of=/mnt/sdcard/sbl3.img
Use gzone CA201L.
Use C811-M040 Software.
Vurizon Unlock. global USIM-SKT
Manual Update failed.
/fota/ipth_package.bin Not applicable.
Rename /mnt/external_sd/update.dat Not applivable.
*** I hope download link ***
google drive, MEGA, dropbox, box
Find M050 FOTA Clean System. dd backup.
/aboot.img 512K
/boot.img 10M
/modem.img 64M
/system.img 1.25G
/rpm.img 512K
/sbl1.img 128K
/sbl2.img 256K
/sbl3.img 512K
/tz.img 512K
Thank you~
Nine days and no response. This update supposidly fixes some nagging issues so if someone can do this it'd be great.
M050 dd backup download link........... ?
Important ones
Code:
su
Code:
Thanks so much for your offer. Doctoror lives in Ukraine. I suspect he won't be calling. If you have adb on a computer you can run the commands above. If you don't then you will need to download and install the android SDK to your computer and then using adb run the above commands.
Important ones
Code:
su
Code:
I typed these in and it says "cannot open for read: Permission denied
in the adb shell
then on the phone i granted it permission.... type it in again and it says the same thing "cannot open for read: Permission denied"
i check root with voodoo root keeper... and it says i have root...
in the adb shell
Totally forgot to say that it sometimes fails as a normal user with this device. Open command prompt as administrator and it should work.
If this doesn't work for him I will be receiving my 5th replacement Commando on Monday. I'll let it update, then I'll root it and get these files. I have an XP machine that works well with ADB.
I apologize for the delayed reply to the file request, I hadn't seen it until now...
Do you stilll need them? I will attach them to my next reply - after I get them from my phone.
I can also email them - if that would be easier.
Ok...so I can email a few of the files. The modem file is 100MB, the recovery file is 10MB and the system file is a whopping 1.25GB.
Thanks. I've updated the OP with big "No longer needed" text. How did you miss it? :confused:
For reference: those files compress very well, so in zip total will be ~800 MB, in 7z even less.
Damn fine question...lol I don't think you could have made the text any bigger...lol
If for whatever reason you do happen to need a "fresh" copy (files are separated), here is a link to my drop box folder.
www.dropbox.com/sh/806lrmwn6av4zq6/r3lEK515__
