I have com across some "important" info (Take it with a pinch of salt on how important you think it to be I don't judge).
I did a Factory Reset of my phone the other day (Being bogged down by apps and I am to lazy to delete them all)and it disabled my function to make or receive calls {Texting as well} (Tracfone is the carrier) *BAD IDEA DO NOT TAKE SHORTCUTS
This link is very detailed about this issue it seems to always happen and only with this model. Tracfone Will fix it.
I do not know the Rules on linking to other posts (This is in the same website so it is not outside to site) Forgive me if I mess up here:
http://androidforums.com/threads/cant-call-barely-receive-calls-since-factory-reset.816599/
I called twice to fix the phone (I was very Lucky on time two to finally get it fixed).
I do know that the ROMS I have encountered in the past reset the phone if we do make a custom ROM I think this info should be considered to avoid having these issues.
Not sure how this would be labeled if we Root then ROM flash the phone If you tell them what it is labeled as I see this as a normal fix rather than a root problem considering the phone take no physical or digital damage (Read below).
Tracfone told me that this is a this as a Server Error that happens with any reset on a ZTE valet and they CAN fix this over the phone NORMAL PROBLEM.
So If you tell it as it is said in the post (That they need to contact Verizon to fix the problem they "may" fix it you may need to remind them a few times without agitating them). {It happens I have done it before we are all human}.
(When I say "may" not all of the tech are not privy to this issue some are)
I think that this is worth talking about considering the tight nut the phone already is while we wait for stayboogy.
And forward this to him if he does not already know.
Hopes for fruitful endeavors are still high.
So any thoughts?
Thanks for reading this long post I am sorry about the time I took from your day just trying to be detailed.
Arcadeon
